Trixz
- 20 jul 2005
- 6.534
- 349
TRX-rijders kunnen zich hier bekend maken en lekker ouwehoeren over hun prachtige twin!
------------Hier staat DEEL 1 én DEEL 2 voor diegene die historie willen zien ------------
Meet, Greet and Ride 2007
---------------------- in organisation by Fuzz10 and M@thijs ??-----------------------------
De 1e TRX MEET,GREET & RIDE (2006) heeft op 10 JUNI plaatgevonden te VORDEN(Achterhoek)
Deelnemers waren;
- Trixz
- Petrus
- TR@X
- noef
- Fuzz10
- anTRiX
- T-power
- Rattle-Head
- TRXArnold
- Wytze850
Foto's voor een impressie...
Engine TRX850:
Engine type = 4-Stroke DOHC 5-Valve Cylinder
Cylinder arrangement = Parallel twin
Displacement = 849 cc
Bore x stroke = 89.5 x 67.5 mm
Compression ratio = 10.5:1
Maximum power (ISO)= 61kW / 82bhp @ 7,500 rpm
Maximum torque = 84N-m / 62ft/lb 6,000 rpm
Lubrication Pressurised = Dry Sump
Transmission TRX850:
Clutch type = Coil spring Wet multiple disc
Transmission type = Constant mesh 5-speed
Gear ratios = 1st: 2.571, 2nd: 1.850, 3rd: 1.428, 4th: 1.173, 5th: 1.037
Frame and Suspension TRX850:
Frame Type/Material = Diamond / Steel Tube
Caster/Trail = 25 degrees / 99 mm
Tyre size (front-rear) = 120/ 60-ZR17 / 160/ 60-ZR17
Brake type (front and rear) = Hydraulic Dual Disc/ Single Disc
Suspension type = Telescopic / Swinging arm
Suspension Adjustment (front) = Spring Preload / Damping
Suspension Adjustment (rear) = Spring Preload/ Rebound/ Compression Damping
Performance TRX850:
Max. Speed = 224kmh/ 139mph
Standing quarter mile (400m) = 11"80secs @183kph/113mph
Power BHP = 76 @7,400rpm
Torque ft/lb = 56 @5,900rpm
Rolling acceration 60kmh-100kmh (37.5mph-62,5mph) in 3rd = 4.4 secs
Rolling acceration 80kmh-120kmh (50mph-75mph) in 3rd = 4.5 secs
Rolling acceration 80kmh-120kmh (50mph-75mph) in 5th = 7.3 secs
Rolling acceration 60km/h-140km/h (37,5mph-87,5mph) in 5th = 15.8 secs
Power to Weight = 0.43 bhp/kg
Fuel Consumption = 45-50mpg
Weights and Measures TRX850:
Length = 2,070 mm
Width = 705 mm
Height = 1,155 mm
Seat height = 795 mm
Wheelbase = 1,430 mm
Ground Clearance = 140 mm
Dry weight = 188 kg
Fully equipped = 206 kg
Engine oil capacity = 4.2
Fuel tank capacity = 18 litres
Links:
TRX850 Germany site
nog een TRX Germany site
TRX picture op BIKEPICS
Zweedse TRX-fanaat
TRX worldregistration site
Franse TRX site 1
Franse TRX site 2
SpondonTRX homepage
YAMAHA TRX850 enthusiasts
TRXfiles UK
Japanse site
Konepool's TRX page
Japanner zijn TRX
Japanse site 2
Duitse test uit 1996
Tjechiesche TRX site
TRX club Denmark
Dé lijst van dé 34! MF TRX riders and one woman ;
- Alias
- Angus
Data:
* Akrapovic single exhaust
- anTRiX
- Aruod
- Derkster
- Dyno_jet
- Ed@TRX
- Fuzz10
(c)2006 Ad Kievit (http/www.wegraceinfo.nl)
- Hazes
- Jobo *streetfighter(look) TE KOOP
Data:
* 1996
* Zwart aangepast frame
* De complete "kont"van een duc monster
* Geen kuip
* Ronde koplamp
* Meesturende tellers en koplamp
* Kevlar remleidingen
* Ingekorte race uitlaten
Wanted:
* ABM stuur met kroonplaat
* Home made achterbrug van dubbele buis (volgt)
- Kars
Data:
* 1998
* ABM kroonplaat
* ABM superbike stuur
* Stahlflex remleidingen
* Bugspoiler
* K&N filter
* Laser Pro Race dempers
- Katrix (inmiddels met 151.000km op de teller ex(trx)-Rattle-head)
Data:
* 1996
* Johnson carbon dempers
* K&N filters+ Factory Pro Kit
* Spiegler remleidingen
* R1 remklauwen en R1 rempomp
* LED Achterlicht 'clear' VTR SP/1
* WP/achterschokbreker
* Thundercat voorvork
- Laxe
- L-TRX
- M@thijs (oude TRX van Schumi)
Data:
* WP voorveren
* Tandwiel verhouding is iets anders
* Stalen remleidingen
* R1 remklauwen
* TWP special valblokken
* BOS uitlaten
* K&N filter
* Dynojet stage....?
* Rearwheel hugger black
- meissie frl.
- Melvin1983
Data:
* 1997
* Compleet OVER RVS uitlaatsysteem
* Open luchtfilter
* Dynojet kit stage 3
* Staalomvlochten remleidingen voor
* Carbon hugger
* Kleinere half-carbon raw's voor + achter
Wanted:
* Crashpads
* Carbon voorspatbord
* Blauwe duozit cover
* Andere kleur kuipruit (Black Smoke of blauw getint)
- Mike B
Data:
* 1996
* Bos dempers
* Dyno-jet kit
* K&N filter
* R6 reminstallatie voorzijde
* Goodridge stalen remslangen voor
* Renntec bagage rekje
* R1 stepjes
* Andere voorveren (geen idee meer welk merk)
- Noef
Data:
* TDM blok
* Verder origineel
* BOS Alu dempers
Still 2 do (this winter):
* Originele tank (zonder deuken)
* Hugger
* Undertray (die nog gespoten moet worden)
- nsr-racer
Data:
* 1999
- Ook een TRiXie
- Paling1 (zijn TRX = R.I.P.)
- Paxxal
Data:
onker ruitje erop
* Belly-pant
* K&N open luchtfiltersetje + toebehoren
* race-kontje erop
In progress:
* Laser Hotcams
- Petrus
Data:
* 1997
* Dé originele mooiste kleur
* K&N filter en dynojet stage 1
* YZF 750 linkhevels (dus achterkant hoger)
* Technoflex progressieve voorveren
* Voortandwiel 16 tands
* Open oval Laser uitlaten (oorspronkelijk bedoeld voor een CBR1100 blackbird)
* Stalen remleidingen voorkant
* Zelfdraai valblokken
- Punica78
- SpondonTRX
- Rokoni
- TeDeuM
Data:
* Hyperpro voorvering (wel deze voor de Franse TRXcup indertijd)
* Tandwiel van 16 ipv 17 vóór
* Alle verlichting is verwijderd
* Monozit
* Dichtgewerkte originele kuip vooraan
* Stalen remleidingen vooraan
* Selfmade valblokken
* Laptimer
* Digitaal snelheidsmetertje (sigma)
* Laser uitlaten(indien toegelaten)
- tiggermac
- TR@X (deel 1 topic starter)
Data:
* K&N stage III filters
* Dynojet kit
* Blokspoiler
* Aangepaste voetsteunen
* WP voorveren
* Rearwheel hugger Carbon
en natuurlijk 'Idiot at the controls'
- TRiX TE KOOP
- Trixz ..... Trixz op de Nordschleife kort filmpje klikkerdeklik
Data:
* 1999
* Bridgestone BT014's
* Braided brake lines front and back
* Dynojet Stage 1
* K&N air intake
* Technoflex suspension
* BSM Vampire exhausts -115dB(A)-
* Wheelrimstriping
* Bikedesign crashpads black
* Small (Smoke) indicators
* Rear seat cover black
* StainlessSteel exhaust mounts with YAMAHA logo
* Rearwheel hugger NWS black
* Pazzo Black Short brake and clutch levers
* Braking Wave front and back
* GP-style gear shift 1 up and 4 down
Wanted:
- Other suspension
- TRXarnold TE KOOP
Data:
* 2000
* Blauwe klauwen voor
* WP-veren voor
* Aangepast luchtfilter en sproeiers etc
* 17-42 tandwielverhouding
* 82 pk aan het achterwiel bij Hoogland motoren
- T-Power
Data:
* 1999
* "Body Style" onderkuipje
* Duozit afdekkap (met het zelfde profiel als de tank)
* BOS dempers met BOS uitlaatsteunen.
* K&N Luchtfilter ipv origineel filter (voor de rest motorisch origineel)
- Wytze850
3x (c)2006 Ad Kievit (http/www.wegraceinfo.nl)
HAVE FUN ON THIS TOPIC
