mzagko
- 8 apr 2021
- 2
- 0
Yes I have 2nd and I am approaching a traffic light so I hold the clutch downshift and then when I try to revmatch the engine is off. It is not happening all the time and downshifting other gears is fine. I noticed that the idle rpm speed is something like 1100-1200. The manual says that the normal is between 1400-1600. I don't know though and I don't want to tinker things there.Does it shut off exactly while revving? And does it start back up right away?
Could it be running too lean? Or maybe the RPMs drop too low after you stop revving?
Otherwise probably the tps like you mentioned.
Maybe check the side stand sensor, kill switch and stuff like that, if they got too loose from vibrations that could be a thing.
Don't really have experience with this problem so these are just some ideas/what I read.
